TwinTurbo.NET: Nissan 300ZX forum - Installed my emblem on a Stillen center panel...
Zxtec
on March 10, 2010 at 10:15 PM
To those with '99 JDM front emblems...
posted by Under_Powered
on March 10, 2010 at 05:58 PM
I did this about 7 years ago so, from what I can recall, I just used wire cutters to cut each pin off. You probably can use a dremel or file to clean it up. Just make sure there are no stubs that protrude above the mounting adhesive.
Under_Powered
17:58:23 03/10/10
Installed my emblem on a Stillen center panel... -
Zxtec
22:15:01 03/10/10
thanks, wire cutters did the trick just fine.
Under_Powered
17:12:28 03/11/10
